TwinTurbo.NET: Nissan 300ZX forum - 2nd... but start with boost leak check (n/m)
CaliguyPurdue (redesigning)
on May 03, 2007 at 3:15 PM
...or crap turbos. (n/m)
posted by YugoBernie (NoVA)
on May 03, 2007 at 02:44 PM
Stock Turbos + Stock Injectors + Z1 Inter-Coolers =
Barry'z (NJ)
13:36:27 05/03/07
Search!!! 7 psi. (n/m)
Spongerider :)
13:39:02 05/03/07
I did and you're right...
Barry'z (NJ)
14:01:10 05/03/07
I think you used too much detail
Spongerider :)
15:08:43 05/03/07
I thought the same thing.
rojoloco (Yokosuka, Japan)
20:46:34 05/03/07
I wouldnt go past 16psi. I would probably leave it at
EricTTZ
13:39:56 05/03/07
Yes, TT Fuel Pump. (n/m)
Barry'z (NJ)
13:42:43 05/03/07
Here's a question for you...
BradZ (FL)
13:44:07 05/03/07
AFAIK, you can drop in the pump, but w/o the TT comp
13:47:15 05/03/07
... I thought the NA had 2 speeds, TT had 3... (n/m)
ZLover4Life
13:54:31 05/03/07
Deuce speeds
14:01:30 05/03/07
Guapo set me straight.
300zx90 (CO)
19:15:06 05/03/07
Thats the aux fan (n/m)
EricTTZ
14:02:07 05/03/07
no, aux fan is 1 speed vs 2 speeds (n/m)
Guapo
14:03:45 05/03/07
agreed. (n/m)
EricTTZ
14:21:10 05/03/07
OEM TT fuel pump controller used 3 different voltage levels
Zirvana
14:11:40 05/03/07
yep ...
Guapo
14:13:53 05/03/07
Then what's up with this Auto-FAQ??
16:01:07 05/03/07
Guapo
16:04:18 05/03/07
(Total Hits: a lot). (n/m)
Spongerider :)
16:16:28 05/03/07
pwned (n/m)
20:01:49 05/03/07
2nd, I dropped a TT pump in the 'vert
vorpalZ
15:40:43 05/03/07
Well what "needs" to be swapped is the pick-up.
Barry'z (NJ)
13:53:58 05/03/07
Cool, thanks...
BradZ (FL)
14:26:06 05/03/07
2nd 16psi - I ran that for a while just fine. (n/m)
ZLover4Life
13:55:07 05/03/07
what ecu? (n/m)
Madhatter10-6
13:40:11 05/03/07
JWT, according to his profile. (n/m)
BradZ (FL)
13:40:59 05/03/07
then he should be good to 13-14 ish (n/m)
Madhatter10-6
13:49:10 05/03/07
Re: Stock Turbos + Stock Injectors + Z1 Inter-Coolers =
Kelticttz
13:40:53 05/03/07
1.0 bar...
BradZ (FL)
13:42:42 05/03/07
So far so good. It took me a bit to figure out
Barry'z (NJ)
14:04:49 05/03/07
there's an OFF feature? Is that also available on the sbc-id
ZEngineer
14:17:59 05/03/07
when rotating between programs, keep dialing down
Guapo
14:22:41 05/03/07
That's how it worked for me the iColor also has an
Barry'z (NJ)
14:37:35 05/03/07
good to know, thanks. (n/m)
ZEngineer
14:43:54 05/03/07
"But this thing goes to eleven." (n/m)
awesom-o
17:58:56 05/03/07
AVC-R measures in kg/cm2 not bar :) (n/m)
OrlandoTT
14:09:23 05/03/07
Well, I was 98.04% corrrect :) (n/m)
BradZ (FL)
14:28:24 05/03/07
I don't know why they did that. (n/m)
OrlandoTT
21:32:17 05/03/07
I ran 15 psi for street driving. >>
Arnel
13:52:15 05/03/07
18 on stock injectors? wow! (n/m)
sfarrah
15:19:20 05/03/07
Yes sir. Close to maxxed out on race gas. (n/m)
Arnel
13:58:03 05/04/07
Here come all the pneubie TT questions again
14:03:26 05/03/07
Oh no...
Barry'z (NJ)
14:06:39 05/03/07
lemme know if the nj crew is setting up a tech day. (n/m)
stockplayerz(nyc)
14:15:17 05/03/07
I'm just breaking your balls man :-P
14:31:01 05/03/07
damn you guys. bunch of characters =P (n/m)
stockplayerz(nyc)
14:14:09 05/03/07
Where are the car pics, Mike? (n/m)
Arnel
14:17:55 05/03/07
hopefully this weekend ;)
stockplayerz(nyc)
14:30:36 05/03/07
This video has been removed due to terms of use violation. (n/m)
YugoBernie (NoVA)
14:51:59 05/03/07
10-13 daily, 15 "hi" (n/m)
YugoBernie (NoVA)
14:16:28 05/03/07
2nd (n/m)
Guapo
14:17:27 05/03/07
3rd. Barry do u have auto spec turbos? (n/m)
ashman2k2
14:39:06 05/03/07
Yes he does. (n/m)
YugoBernie (NoVA)
14:45:17 05/03/07
16 psi as a high setting and 10psi low.. (n/m)
97modman(NJ)
14:17:52 05/03/07
Contact your installer...he loves these kinds of questions. (n/m)
Fuzznutz
14:19:12 05/03/07
I've yet to hit mine more than 9... I think Tim made
telegraph(Denver)
14:27:39 05/03/07
YugoBernie (NoVA)
14:44:41 05/03/07
! (n/m)
telegraph(Denver)
14:49:19 05/03/07
2nd... but start with boost leak check (n/m) -
15:15:33 05/03/07
Push the pedal on the right down more. (n/m)
Woody75 (Denver)
15:10:52 05/03/07
in your opinion they are boosting okay? (n/m)
telegraph(Denver)
15:12:39 05/03/07
You saw me boosting 11-12 just fine. (n/m)
Woody75 (Denver)
15:18:33 05/03/07
excellent... if you say they are boosting good (n/m)
telegraph(Denver)
15:25:24 05/03/07
Today I hit 1.18 hkpa (17.1 psi) according to the peak hold
Barry'z (NJ)
15:14:49 05/03/07
Re: Today I hit 1.18 hkpa (17.1 psi) according to the peak h
ZDUCTIV
23:11:48 05/03/07
I would think 16psi on 93 if available..
TyreeZtt (SeKy)
14:56:09 05/03/07
93 is all I use. (n/m)
Barry'z (NJ)
15:25:16 05/03/07
Shweet. I think you will be fine @16psi. (n/m)
TyreeZtt (SeKy)
17:35:57 05/03/07
wheres the official barry TT 2+2 pic thread? (n/m)
josh
15:35:20 05/03/07
Like every other adolescent boy who just discovered himself,
Dave N
15:43:43 05/03/07
Unlike the ones that have already discovered themselves...
Z_Cherub79
15:50:07 05/03/07
Correct you are dave, and the only thing that looks
Barry'z (NJ)
15:53:42 05/03/07
Feel free to elaborate... :-) (n/m)
YugoBernie (NoVA)
17:03:05 05/03/07
LoL!! (n/m)
Spongerider :)
15:56:44 05/03/07
Are you setting up the boost level on auto or manual?
Neogenesis
16:40:24 05/03/07
I'm using Auto, so far so good.
Barry'z (NJ)
19:02:55 05/03/07
Auto Vs. Manual
ZDUCTIV
19:14:33 05/03/07
I got it setup just the way I like it with the manual setup
Neogenesis
21:28:52 05/03/07
Thanks, I'll give it a try. (n/m)
Barry'z (NJ)
14:17:32 05/04/07
Use the manual settings. (n/m)
YugoBernie (NoVA)
23:29:19 05/03/07
Ok, I'll give the manual settings a shot...
Barry'z (NJ)
09:21:48 05/04/07
On my Greddy spec 2...
Fuzznutz
19:09:29 05/04/07
Thanks Bob, much appreciated. (n/m)
Barry'z (NJ)
19:39:13 05/04/07
The injectors are your limiter, too much boost = lean
300zx90 (CO)
19:09:19 05/03/07
